chrisk
- Brisbane, Australia
I have this leak in my Monza fuel cap, that I thought was coming from the fitting edge of the filler.
With tank empty, I closed petcocks and cap, and blew compressed air up the venting tube.
There was more air exiting the filler cap proper than I had expected.
On closer examination I note a (about 3mm dia) venting hole on the spring loaded sealing part of the cap proper.
Has anyone else found this problem on the Monza caps? I googled the problem, and Triumph and Norton forums were talking about a similar leak on Monza caps, but nobody found a fix.
As I have a separate vent outlet, I'm contemplating sealing up the hole.
