Robin Webster
- Silverstone
Right so having dyno'd it we decided to give it another run next week with some longer inlet trumpets. I bought some and thought I'd just spend 15 min popping them on. Some hope, three hours later.......
I took the carbs off to get the trumpets on as it was a bit tight and also ended up loosening the inlet manifold to help with the job. Thought I dropped a 7mm nut down behind the starter motor so took that out. Bloody nut was on the floor any way..
Put it all back together and it wouldn't turn over on the starter. Just a click. Starter motor off, apply electricity and wizz it goes. Put it back in and it's no go.
Motor is not seezed.
Is it the starter motor clutch or does my battery need a charge??
Robin. (banghead)
Robin. (banghead)
