piranha-bro2
- Melbourne
Vince said:So I thought peak toque occurred at 4500 rpm and that's around where I usually ride at or was till I melted the inlet ring land off 2 pistons. Seems That's considered lugging it and I should be running my race engine, it has been upped to Corsa spec, mostly at 6k and up to avoid damaging it. What did surprise me was the compression reading from a test, it was producing 195psi.
Couldn't think of anything worse! 6k?! If 4500rpm is lugging it, then something ain't right - it's not a ZZR250 Vince!! Just about every modern car on the road is heavily geared to keep revs as low as poss at cruising highway/freeway speeds. I just never labour any engine. Simple. If I can put the car (turbo diesel) in 5th at 60kph with little load (flat or downhill) I'm more than happy to do it.
Hi comp moto engines tell you when they are under loads they don't like - if you have the right 'feel' or 'engineering sensitivity' ... it's what also makes some racers much more reliable finishers.
Glad I'm not the only one confused by the BMEP ...
