Hi just a quikkie does anybody know a replacement rear wheel spindle for a mk3 motodd "box section swing arm" ie. one off something else that will fit suzuki etc??????
Hi andy - The SFC1000 RW spindle is long enough - We used a 17mm silver steel bar with the 16mm*1.5mm threads cut onto it. May need some tiny diameter reduction for the original wheel bearings. - regards - Phil
I juts had to get an angle grinder involved in removing mine which is in 3 bits after LH side wheel bearing decided to bite it half way out not a pretty site 2 days sweating and swearing at it first tho'..... it didnt want to let go and still wont bugde off after belting the bit left over with a flogging hammer in the vice....
