Axel said:As anyone tried running the clutch with a. 4 instead of 6 springs or b adding a washer or two to all 6 springs to reduce the preload?
Roger
Grant said:Dreaded
Roger
Axel said:Dellortoman
Thanks for your advice.lve ordered a MK3 actuator arm from Greg Parrish at Dam Racing. I'm baffled by your comments re additional washers as several sites say adding a washer Decreases the preload.
Roger
sfcpiet said:Depends on where they are placed.
Dellortoman said:OK, I give up. Where can you put washers in a Laverda clutch to reduce spring preload?
