Need 3.2 mm shim
martymoose said:
For Jota 7606. New buckets are thinner
Re-ground?  Check for surface hardness!
Normal thickness ranges from 2.20 -2.22mm.  The hardening of the buckets is quite thin, I've seen a few re-ground ones fail.  I don't remove more than 0.03-0.04mm to clean them up, if more is required they land in the bin...
