ludiluka said:
Not familiar with triples but it could be bad coil for cilinder 3. Usualy if coil is bad it stops working when it get hot
on 180 triples, only two coils.
-One coil with single plug wire, to the center cylinder.
-2nd coil, with two plug wires, to cylinders one and three.
old saying, 90% of carb problems are electrical, so switch the plug wire from cylinder 3 to cylinder 1, and vice versa. If problem switches cylinders, you have a bad spark plug cap or plug wire.
if problem persists on same cylinder, look to the carbs
-vacuum leak on intake cylinder number 3?
-choke plunger not adjusted properly? Has to "seat" deep enough on the adjuster to close off the opening in the bottom of the hole when choke closed. How are the rubber choke plunger tips?
-basic carb setup?
-about a 55 - 60 pilot jet. On what you are describing, go to at least a set of 60's, 55's may be too small, 50's definitely way too small. 65's are usually stinky rich, but some bikes like them.
-Idle mixture screw? - rubber O ring in place with steel washer behind? Initial setting one and one half turns out from fully seated. -New needles, K1, middle notch, needle jet AB 265.
-Basic mechanical synchronization of the three slides, as close as possible to the same heights?
-Float level set properly and the same on all three carbs?
-Main jets irrelevant to your issue, but ultimately you will likely wind up around 118 - 130 range, although 130 will likely be too rich.
also, not to be a smart ass, but do pop the valve cover off and check the valve clearances on cylinder 3, make sure you have correct clearances.
for the charging light, once you get the bike to idle, put a voltmeter on the battery pos and neg and read the voltage. Turn the headlight off. At idle you would hope to see at least 12.5 volts, hopefully more. Then rev the bike to say 3,500 rpm while watching the voltage and the charge light. By 3,500 rpm you should be getting at least 13.75 volts and the charge light should have gone out. If not, you have an issue with charging coil, if you still have original stock weak charging system, or possibly also with regulator/rectifier if your bike was late enough in production to have a rec/reg? Bottom line, you need to put a voltmeter on the bike while it is running to determine if you have adequate charging. If the bike is charging correctly, for fun turn the headlight on while voltmeter still hooked up, watch how much voltage drops, the old charging systems can barely run the headlight.......
Paul LeClair
