IIS
Hello Cam,
You certainly have the hands on ( actual research ) to know the effects that are being discussed here. Been sussing it over in my mind as to reasons for the readings at RM's Dyno, we all know Red and helpers are no beginner at this. He is reading something, and like you i wonder any number or all, of what is occurring. If the presence of the internal sensor is altering the characteristic and or gas flow properties, or it is so good it is measuring peak thermal mass ie un-burnt/burning mixture due to higher back pressure, between probe point of interference and combustion chamber. So many imponderables, hypothesis etc etc.
Emissivity of differing surfaces is well known these days in regard to non contact thermal measuring devices. There were tables with correction factors floating around some where. Anyway, with a TC probe and non contact thermal device in hand and the dyno at work, Red can create his own correction tables, even throw in the internal probe data onto a spreadsheet. Can bring a Fluke industrial grade twin TC hand held meter to confirm readings on the Dyno, what i calibrated the IIS TC model against.
One key point is that no matter the actual exhaust gas temperature, it is all but dissipated by muffler outlet, ie you can hold your hand against the exhaust gas pulse comfortably. That is some "thermal loss" over a matter of milliseconds. Suggests the actual thermal inertia or mass of the gas is very low, extremely low i would suggest. Interested in your thoughts, even though we are both engineering tragic(s), well better speak for myself... you may well have obtained a better place than me, grin.
Regards from John.
Regards from John.
