Hi all
Have just purchased a 3cl 1000 from New Zealand - I understand that it was originally sold in Australia and then went to NZ. It has been modified a bit with later model wheels and I am told Jota cams.
It started up here, but was very rattly - the timing chain was adjusted and it sounded better..
I have only ridden it a few kms..
The other day I started it and it ran briefly - I turned the choke off and it stalled and I was unable to re-start it.
There appears to be no spark in the outside cylinders - but the middle cylinder has a good spark.
The ignition system is an IIS TA 180.
It this likely to be a coil problem - or could it be an ignition system problem?
I should mention that I am not even close to an expert mechanic/auto electrician. I have been looking through some of the older posts and been unable to fully understand much of what has been written about the electrical system of these bikes.
I would appreciate any advice.
Regards
David
Sydney Australia
Regards
David
Sydney Australia
