I'm trying to replace oil and water hoses on my car, and they want many dollars. Some are not available as aftermarket fittings.
As a sparky I quite often cold bend and heat bend conduit, and with my stuffing around in the shed, Perspex, plastics, blah blah blah. Not that I really understand the composition.
BUT, If I buy a straight length of oil resistant hose, say 25mm ID, put an internal bending spring through it, set out a pattern on say a block of wood, is there any process I can use that will "set" the hose to the shape?
Regards, Greg
Regards, Greg
