Nylon-Coated Parts
  • Thread starter Thread starter Grant
  • Start date Start date
G
Grant
Guest
I have a few brackets and stuff that at some point has been nylon-coated.
Due to wear and also corrosion underneath I want to remove it.
Does anyone know a good way to remove it cleanly without damaging the item itself?
  Bit of gentle heat then peel it off, blasting is no good as the soft nylon coating tends to absorb the impact of the blast media, the stuff never really sticks to the metal underneath (hence the corrosion) so it generaly comes off easy enough.
    Keith
I have a rear rack (looks to be brazed) and a clock binnacle (alloy) that have some easy to peel sections (like popping bubble wrap. very satisfying) and some areas that adhere very well.
I had thought about heat but wondered if that would promote adhesion.
I'll give it a try.
Ta
