R
Reggie3cl
Guest
OK, so I've got power to everything. Move the cutout on the crank rotor to the firing position, set Witt to '0' and switch on ignition. Nowt, nothing nada.
Then after about 10 seconds or so, off she goes. Switch off and back on and off it goes again, sparking at about 3500 RPM. Leave for a few minutes, try again and same thing, ten seconds (without touching the bike) and it starts firing.
Check all connections, wiggle wires etc etc. but the same thing- if the bike is switched off for any length of time it won't fire immediately, but if I switch it off and on immediately it fires. Switches are good, I'm confused. Is my ignition about to blow?
