jdugen
- Manchester UK
Hi all.
I replaced my original inner case with a cut out one for the extended release arm. Didn't realise that these are not fit and forget until I found a lack of fifth and a failure of the gear lever to return properly. I've gone through the setup procedures so hopefully I should be back in business.
My question is regarding the selector drum pins. Three of them are a loose fit and drop out easily, the others are tight in the drum. Which is correct or does it make no difference?
My musings are that the loose pins will ease the wear on the selector arm hooks by being able to turn as the hooks engage them. Or, will this looseness add slop to the mechanism?
Thoughts people?
Cheers.
Thoughts people?
Cheers.
