Oil capacity RGS ?
I fill mine right to the top, and then lay it over at 45 degrees to get the correct level.  Just be careful picking it up with all that oil on the garage floor.
Don't you know you can't start a sentence with a numeral?
Should be: Five and a quarter pints................. (bolt)
Dipstick?  There's a cork in the oil filler hole, seems to work fine.
Your lucky to have an oil hole to fill with, for some crazy reason my oil fill hole on the Pantah is virtually completely covered with clutch hub. It would take an hour to dribble it in past this. I now pull the 32mm timing slight glass out and fill through it.That now takes the usual 5 minutes.
