bob said:Now my question is this; when you fill a completely dry engine with the manufacturers recommended amount of oil, what's the dipstick reading once the engine has been started and the oil has found its way up into the cooler and into the primary case. Are the manufacturers dipstick marks corrected to allow for that?
Bob,
When rebuilding, I fill 3 litres to a fresh engine. Dip stick usually shows up "full". Checking after initial start-up shows dip stick on "low", nearly 0.5 litres needed to top up.
