oil dipstick monti mk1
Hi Ian,
Under racing conditions it seems the vibration causes the metal part of the dip stick to break up where it joins the threaded top.I noticed mine was breaking up before it actually fell away!Don't use any more made up a alloy top to seal hole,and just use dip stick to check oil level.
If you run with out the balance shaft its more likely to happen!
I spoke to Richard Slater at the time  who confirmed it happens.
If I was you I'd make up or get one made,just a skrew in top say out of alloy.
I lock wire mine,drilled a hole in the alloy ledge of the starter motor housing to wire it too.
Andy
Thanks Andy, just what I was thinking.. and yes, no balance shaft in mine..
Easy enuff to make a screw in cap.. :D
On with the job lads..
8)
Ereka kakakakaarrrrr !!! :o  got it fired up today after 7 yrs  needles stuck tap tap ok!spat at me once and fludded,forgot to use choke,didnt know it had choke! :o cleaned plugs again on the button now 8) :D tempted to ride it but no brakes!! :'(
