the hoses on Piero's space frame are a lot longer as well, and they can give a lot of trouble if you fit the wrong type, (ask Rufus!) the higher you put that oil cooler the harde the oil pump has got to work to "push2 the lube over it and into the motor, so be carefull.
by the way, a "pikey" does generally do all those things stated in post 5 or 5 and more besides, the term is used to describe less than desirable citizens quite correctly but the word "gypsey" has become badly used, a real gypsey does not do those things, nor would an Innuit (eskimo) or Sami (Lap) I know a few of all of those last categories including real gypsey's, Ronnie Wood is one of them from a familly of water gypseys, and the last in his line to be born on board a boat
