Oil leak 880SFCK
Tippie said:
You do mean AB265 which are standard for just about any of these Dells I have ever seen.
No, AB260, I have AB256 in them now. Eurocarbs sell same carb, with K4 Needles and AB260 tubes. Are you saying to use K4 with AB265 tubes?
Chris, the only change we made was to fit K4s. No need to do anything else. The carburation was fine elsewhere, just the main jet restriction issue was dealt with.
Don't bother with dome nuts anywhere but that one stud with passage to the oil. Would look a bit naff, I reckon! If the dome nut is too short, just add a few more washers!
OK, thanks for the carb advise. BTW, I will leave my front nuts alone.  :o
Remove oil,
Remove stud,
Clean Well,
Soorten stud to correct length,
Re- fit stud with loctite,
Fit std washer and nut.
Advantage?
Lighter,  :D
No leak and pissing around for a special nut etc,
The clamping force with a harder wasbeer is significantst more than a soft one, copper is even worse,
Peace of mind That its right.
J
nice idea Julian, and perfectly sensible in almost all cases (no pun intended) but with Laverda's there is a strong tendency when removing studs that have been in situ for 40 years, and were possibly screwed into steaming hot cases (for retention) that you will get the stud out OK, and it will have a nice coating of crankcase thread on it as well!
best to leave stud in situ, because Helicoiling/Timcerting on a built motor is very often impossible, due to access.
If you can get a 4" grinder with a 1mm disc near it, or even a junior hacksaw, or even just the blade, then maybe trim the stud in situ, but I would be reluctant to remove it, as you suggest.
