Tippie
- Dr?bak, Norway
Thanks Cam. I was hoping for such an explanation. We?ve had a bout of rec/reg replacements lately within the family fleet.
Sorry to correct you, but usually not DC output is grounded, but AC coils of the altenator are grounded by the the regulator SCRs to control max. voltage.Dellortoman said:Nit quite Lee. Simple diode bridge yes. That's the rectifier part. But in the regulator part, voltage isn't controlled by resistors.
But when the system voltage exceeds a set level, the DC output from the regulator is redirected (or shunted) to earth.
Gravelroad said:Sorry to correct you, but usually not DC output is grounded, but AC coils of the altenator are grounded by the the regulator SCRs to control max. voltage.![]()
