Parts Diagram Rear Axle SFC
Installed a new rear cog and chain on my SFC this past weekend, and noted a washer on the ground, not far from the bike, when I was done. Now, I had a lot of tools and stuff out on the floor, and the cog was not he only job being done, but this was disconcerting, to say the least. The rear wheel does not appear to bind at all (has new greased up chain so action is not as loose as with run in chain), and when I removed the wheel I noted how tight the fit was, felt like spacing required the rear swingarm to be spread slightly. When I reinstalled went in fine, and now spacing appears correct...but still the matter of that washer, which fits the rear axle, by the way. Axle has, viewing from rear left to right, nut, washer, chain adjuster, rear brake mount, spacer, left side bearing, spacer, right side of wheel bearing, washer, left side carrier bearing, spacer, right side carrier bearing, right side chain adjuster, washer, right side nut. To be safe, anyone know of a part diagram of the rear SFC axle? Can find many of the rear SFC drum brake, but none of the SFC. By the way, 530 O ring chain clears engine case by a couple of hairs, and does not appear to rub, but is close enough that it likely will contact now and then. Will have to watch this, though it may machine itself to correct any clearance issues....
Stefan: Thanks, but I note the cast wheel assembly on Andy's site is a bit different thatn the Borrani wheel assembly.
Gert: Thanks for parts diagram for Borrani wheel 750SFC. Confirms that the washer, if in fact it came off the bike, was superfluous, because I have all of the parts shown. Thanks again, and where did you find this diagram?
... I am happy to have the original 750 SFC/1974 and also the 750 SFC Electronica/1975-76 handbook in my archive!
Ciao, Gert
Bought my Electronica manual at the factory in 1977, worn out more in the years dreaming of owning one than during the years of ownership of the machine..  :P
Marnix
Hi Marnix, I dreamed about 30 years of a Laverda 750 SFC, bought my Electronica in Sept. 2002 and found the original manual in nearly new condition some weeks later at the Mostra Scambio in Imola - I payed EUR 20,-!!!!!
Ciao, Gert
