I just called Megacycle Camshafts yesterday for some questions about their hardening process, in relation to using a nitride vs tungsten disulphide low friction coating on the cam lobes. They pleaded with me not to do it, saying the surface finish on their cam lobes is precision ground to the optimal roughness to just allow a thin film of oil to spread outwards from the "scratches" to keep the lobe surface lubricated at the speeds and loads associated with motorcycle camshafts, and their hard coating is already lower friction than steel on steel. They said the only way I could get an improvement would be to have the tappets micropolished before coating them, and I have no way to find out what hardening process was originally used on the tappets. The techs recommended Motul 20/50 motorcycle oil, no additives, and no surface treatments.
I was very surprised, but the 2 people I talked to both knew what Laverdas were, and discussed how the lubrication needs for a Laverda twin were different from the optimum for a Laverda triple. They said that there's a lot of Laverdas "coming out of the woodwork" at the moment. Not sure how to interpret that.
Ken
