Rusty Spokes
- Decatur, Ga. USA
I concur with Lothar..the chokes on my Dells were very generous and once the engine fired up. get that choke OFF. Dropping the choke jets for #60 from #70 made a significant improvement in cold starting and manageable enrichment.
I still get off that choke almost immediately when the engine is running. #60 choke jets eliminated any plug problems too.
And Clem if some used Laverda HC pistons have value to you..you can have a set of first oversize 75.4mm HC pistons. No charge. Top ring lands are fractionally out of spec. Skirts and piston pins are fine. Just let me know.
I just swapped out those 1975 HC pistons for some Ross 77mm HC slugs. Very nice results. I had to use a very thin home-made cylinder base gasket to get the piston squish right. Engine pulls like a freight train with Axtells, a flow-ported head with Wolfgang's big bore downpipes and a beautiful big bore collector.
