Hi all,
I need a set of pistons for a SF2 engine and now I am checking what suits best.
What I have and what is fixed for that engine: Standard motor with standard crank. Bore will be 82mm. 36mm carbs. Standard head or slightly modified head with C5/C6 like cams. It will be ambitiously used on racetracks but for fun.
First thing I am not sure about: The weight of the pistons.
An Asso piston with pin weights about 440gr a Mondial piston about 390gr as far as I know. I did read of much more lighter pistons.
Does anyone have experience, which weight works best in high revs? Without modifying crank. Perhaps a very light piston would be counterproductive in that setup regarding performance and vibrations?
Second thing: The compression ratio should be about 10:1. What is available? Which pistons are in stock in the world now? Any suggestions?
cheers, Jens
cheers, Jens
