Dear friends,
I am just new on the forum, I'm a Spanish guy who has since one year back an Alpino 500 bike, I bought it from a guy who keep it in a reasonable good external look but with no so good health inside.
I have a strange problem with the way that the bike runs, it starts well and after around a minute with the choke on she idles quite happily, the problem is that you can not increase the speed above 110-120 Km/hr. It seems as the gearbox was in need of another 6 gears!, there is no appreciable difference on speed from 5Th to 6Th gear, and you can insert all like in a motocrosser bike, in 100 meters all are in!
The pinion and rear sprocket are the standard ones.
It pulls well from the bottom, at least that is my feeling, and the tacho needle goes up very quick, perhaps too quick...
I have checked with the previous owner, as I was in doubt that perhaps he had change the gears for the Atlas ones (thinking that they could have a shorter ratio), but he has confirmed that the gears were the Alpino standard ones, he has told me that he opened the engine to clean the inside and just replacing the chain slider.
Being sure that it was not a solution, but not knowing what else to do, I have tried with the main jet going from 115 to 130, but nothing positive happens.
Also I tried with a 2 into 1 (Montjuic style) pipe, but out of a tremendous and pleasant noise no speed improvement at all.
I do not need a speed record breaker but I understand that she should be able to run at 150-160 easily.
Please, I need your help to try to find the origin of my problem.
Any idea?
Please, here around there are no many people with enough mechanical knowledge about these bikes, so your inputs will be welcome.
By the way, sorry for my poor English.
Best regards,
OssaF3 (I?aki)
Any idea?
Best regards,
OssaF3 (I?aki)
