plug leads for Nology coils
2volts
can someone please point me to some suitable plug leads readily available in Australia that will fit onto these Nology coils?
thanks
pete
The fitting is the same as a spark plug tip. There are right angle plug caps available with zero resistance into which you can insert your desired leads. NGK do them, your local mower/chainsaw shop will carry something also.
Pete
With the coils you should have got the fittings, just find some good quality copper coil plug lead, swage on the fittings supplied one end and your choice of plug caps the other. I prefer NGK caps.
If you havent got the fittings then any auto electician who has been in buisiness for more than a few years should have heaps floating around just waiting for someone like you to come biuy and pick some up... he would also have good copper core wire.
You could always try one of the motor factor stores such as Repco/Bursons etc..
Or if you are stuck then send me a PM and will sort you out with some
