At first i would check the balance between both carburatores with a cheap trick:
You need only
- one more spark plug
- a grip pliers or a throttle with a screw to blockade or a tape or a second person
- Drive normal some kilometers/miles till the motor has his normal temperature at work.
- put the bike on the centerstand (motor off).
- take away the left spark-plug cap, stick the third spark plug in it and ground the spark plug on ground (engine case)
- start the engine (right cylinder), sometimes you need additionally the choke
- turn the motor to 3.500 u/min and blockade the throttle safely with a methode i wrote at the beginning.
- turn off the ignition
- change the external third spark plug from left to right (of course the left spark plug cap has to be on its normal place)
- ignition on and start the motor (left cylinder), maybe with choke
- if your balance between the carburators is correct, your motor should have the same rpm at 3.500 as the right cylinder from the first run.
If not, depending of your rpm you have to tight or loosen the throttle-cable on top of the left carburator.
With the correct adjustment the motor will work like new born.
If you want to to the maximum, you can check/correct before this cheap trick the clearence of rhe rockers (?) of your cam and the ignition.
After that, normaly the color of the spark plugs will be identical if you don't have generally a problem with your carburators or your motor.
Try it out, you will see it works!
Best Thomas aus LAU
