Rufustbear
- Manchester
Rebuilding my jota moter after going bang at spa last year,seams a shame to put her back in and not polish the down pipes and box any one know of an easy way of polishing these items back to standard ?
mcnicol said:BTW I never responded to your question about the hole in my primary cover, I saw your question but couldn't find it when I went back to respond. The inner race on my outer crankshaft bearing in the primary cover was badly worn, I'd bought a new bearing and was about to replace it first chance I got ( :). When I went to get on the bike to come home from work I noticed that the worn part of the race had managed to gain enough purchase on the rollers that as the very slightly out of round crank (still within spec but only just)whipped in tiny circles it "screwed" the inner race out against and eventually through the case.
So I had to have the cover welded up and bored, new bearing, slapped it back together, but I've lost a lot of confidence now. I keep looking down to see if it's happened again. I need to have my spare crank rebuilt so I can swap it one day when I've got the time, but with absolutely nobody to help if I realise it's more than I can do, it's pretty scary.
laverdakeith said:Kinda off topic then back on a bit..
I think you would be very hard pushed to find any measurable gain by wraping your exhaust pipes on a motorcycle, on a car for sure as it will keep the under bonnet (hood) temperatures and therefore the inlet charge temperature down a bit, even if it did produce a fraction of a horsepower more I still think I would avoid the stuff on looks alone but that is a purely personal preferance based on asthetics.
You can get a good as new shine on stainless with some Solvol and plenty elbow grease, takes a couple of hours but it has the added side effect of toning up the wanking muscles. 8)
Keith.
