Alexb83
- Northumberland
I'm not denying that they made versions with a starter button, Jo, or that they were used on contemporary Laverdas - but I cannot see the starter button and necessary third wire on these pictures of the unit for sale in the link you posted above.No, the pic of the used one also showed a starter button. Anyway, Suzuki built the same switch gear with and without a start button, with one and two throttle-cable connections; it was a modular concept. And, most importantly, they're identical to those on contemporary Laverdas ...
They clearly made several different variations using the same basic metal castings, but unless you find exactly the right one (two cables, kill switch and starter button), they will need some remachining to work.
