Generally I agree, but I would like to level a bit too. On my former RGS I had the original AG Strada, as you, and they were rebuilt after 70.000 km's. They worked fine at that point.
When I sold it, 7 years later, it had done 116.000 km's and they worked perfect.
No promblem what so ever.
Marzocchi AG Strada do not have to be that bad. And contrary to all the set of Koni's that later went on the RGS series type of frames, the Marzocchi's are not too short.
Personally I prefer them over a set of Koni (original Koni's, no copies). They actually work, and can be adjusted in springpreload and airpressure. Koni's can adjust springload and return dampening, but are a block of steel no matter what.
I now got a set of ?hlins (S36P) which is absolutely perfect. I just had then rebuilt to be S36PL instead, to raise the rear a bit, without affecting the springs or dampening.
Here in Denmark, they are cheaper than compared to say UK, Germany, Sweeden, France etc.
These dampers you can have built exactly for you, and there's a wide range of internal valves, springs, adapters (lengthwise), preload manual and hydraulic and so on to choose from.
And I don't have to send them abroad to have them rebuilt sometime in the future, but can have it done locally, 5 km's from where I live.
Hope it's of any good use to you.
Jacques.
