blab
- Adelaide South Australia
Gazzi shocks, 81 Jota.
I am trying to work out what washers to use to allow the shocker to swing freely.
The upper bolts appear to be a special stepped bolt.
Its a 12mm bolt 75mm long with a 14mm shoulder 22mm long.
The bush in the shock eye is 14mm ID 16mm OD and 20mm long.
Do I need a 12mm washer between the shoulder and frame ?
Without a washer under the head of the bolt the shock bush has 2mm lateral movement.
Do I use a 14mm washer 2mm thick and have the bush tight between washer and frame,or a thinner washer to allow some clearance and allow the bush to rotate on the bolt ?
I noticed with the top bolts removed, one shock swings freely,the other is tight !
Also one top bolt has had 5mm cut off, the longer bolt hits the mudguard if put in that side,very strange.
These bolts were used with a grab rail when I got the bike, meaning that the shoulder got no where near the frame.
Are longer shoulder bolts needed with the grab rail.
