Rearsets and left foot brake - help please
Alexol
A little help please -
If someone has Tarozzi rearsets and left foot brake, please could you send me a picture or two of how the master cylinder is mounted.
Currently I have the footrest in the standard (forward) position with the master cylinder inboard of the frame.  To use the rearsets, it looks like the master cylinder has to be mounted outboard the frame, but not quite sure how it should fit relative to everything else.
Any help would be very much appreciated please, pictures especially.
Thanks in advance,
Alex
BTW, if it is easier to email pictures to me directly my address is alex then the usual symbol followed by dcs306 d o t  com
The m/c does not change position.
The pivot shaft through the frame is still used with linkage to the m/c.
You need a chromed link from the outside of the pivot shaft that the linkage from the brake pedal fixes to.
I'll have a look for photos.
Thanks very much, Grant - very much appreciated! The picture makes sense of it.
I'll go play with my box of bits and see exactly what I've got.
Alex
