Reassembling the RGS1000SFC
Rockitdoc
Hi,
I'm finally getting back to reassembling my bike and need your advice, as usual.
Do you guys recommend using a gasket sealer on the gasket between the block and the barrels?  If so, which one?  If not, why not?
What about elsewhere on the motor?
Thanks, in advance.
Scott
hi scott, would only use wellseal on the crankcase's as there's no gasket anyway, every where else I just use a touch of  grease . if you use a sealer on the barrels or head you may have problems getting them apart in the future. also don't use cheap pattern gaskets because they may well be the wrong thickness. I am also doing a rebuild on a sfc 1000 which I brought from good old scrumpy
best regards andy
Barrels going on.  Ugh!
Don't drink too much while you have a spanner in your hand.  That's my advice.
