L
laverlesmains
Guest
After a front end rebuild I'm reassembling everything. I seem to be missing a fork yoke washer or two..
I installed the lower triple clamp ok, and used the under yoke nut with a large washer to tighten it up to the bearings.
I then install the upper triple clamp, and when tightening the upper yoke nut it bottoms out against the lower nut. In other words, with the upper nut tightened as far as it can go, the upper triple clamp can rotate back and forth. Looks like I need about 1-2mm of washer to take up the space
In looking at the parts fiche online it doesn't seem that I'm missing any washers or spacers.. Is there some magic that I'm overlooking?
Thanks, Tim
Thanks, Tim
