breganzane
- NSW Australia
Part 34 is a crude one-way valve. If I'm recalling the whole thing correctly, then it sits up against the steel ring with the three cutouts on the inside, and is kept captive in a counter bore in the aluminium insert in the bottom of the fork leg. Oil flowing in one direction will push part #34 down against the flat face of the aluminium insert, forming something of a seal. Oil flowing in the other direction pushes it against the steel ring with the cutouts, which creates an annular area for oil to flow past it. Therefore I guess it must be that the smaller diameter end of part #34 sits up against the steel ring with the cutouts.
In the end this may not be your problem but that is what it does and it's worth a look.
SteveB
SteveB
