Gareth99
Following an "off" at Cadwell at the end of last season I had to completely strip down the Laverda to make sure there was no crank damage (fortunately there wasn't), and I'll post photos on here of the rebuild.
I took the opportunity to get the engine soda blasted and the casings polished, and the frame powder coated. Due to the time taken to get the engine casings back after a very busy Stafford show, I wasn't able to start reassembly until last week.
Things were going well until I noticed a small crack in the lower of one of the piston rings on the LHS piston and sure enough, just as I touched it, a part flew off and into the engine casing! Grrrr!! luckily I could fish out with a magnet and after much checking that I'd got all the offending parts, I ordered another set of rings.
Next job will be to rebuild the clutch cush drive with new rubbers.
