Dale said:Thanks, Guy's.
It looks like nothing will be easy with this one.
Dale
Actually it's quite easy. You take the swinger, the new bushes, and the old worn hardened spacer to your local expert machine shop, say "Please press these bushings in and ream them to fit this spacer, and please be sure that they're in line with one another". When they say "Sure, no worries" you press your luck a little bit and ask just how they propose to do this. If you're not satisfied with their answer you take half a day off work and drive to the other machine shop way on the other side of town and go through the same process with them.SimonR501 said:The more tricky bit is getting the bores of the two bushes on the same axis and with the correct clearance.
