RGS carburetor layout
murphus
Finally getting around to getting the "Colorado" RGS running and noticed the carbs appear to have been rebuilt and put back together incorrectly. To wit, the fuel/air mixture screws on the left and right carbs point inside, not outside, and the right carb overflow line is to the outside, not the inside. My assumption is that whoever did the work removed the carburetor tops and then inadvertently bolted the right carb to the left top, etc... Am I correct that the fuel/air screws should be to the outside on the left and right carbs?
Yes, you are correct. Fuel line routing should be interesting for clamp tightening! Time for a complete rebuild-
