RGS Clutch/Primary
There's no spring in my clutch slave cylinder and it works perfectly, no need for pumping, the clutch is lightish and always feels the same.
As I have one of these low drag bleeding nipples (broken off) I had to bleed it roughly by holding at the right angle and trying to get as much air out when putting the slave cylinder back in. I know there's some air in there still, maybe it's acting as the spring? Doesn't seem to affect tjhe operation though.
Mechanics used to throw away that spring at the first service. Said it wasn't needed and could wear through the casing.
