Sir Sidney Ruffdiamond
- Cotwolds
Gauge showing nothing when all connected up ! but if i disconnect the harness from the sensor the following
I have twelve volts from the two red wires coming from the clocks - individualing earthing them brings the fuel light on and the second the needle goes to full
If i check the continuity between the two spade connectors on the sensor i get a resistance
The third wire is earth if i disconnect it and check continuity with earth on the wire its fine
The post it connects to on the base of the sensor shows nothing
How does the circuit work - does the sensor internally earth the two live circuits to the post with the green wire and create a a level and at the bottom excite the light ?
Any theories or just a *ucked sensor
