RGS Fuel tank cap
They come from Wolfgang Haerter Bruce.. ;), or failing that Andy Wagner.. whole lot easier than farting around with car dealers..
8)
1200ts said:
Which model Fiat?
IIrc, Fiat Uno/Ritmo.  Won't find many on the roads, all turned to iron oxide by now... :D  Demand for parts for these will be quite low, might be able to snatch up a cheap batch!
Even now, I still don't know how you remember all this stuff, Piet.  (You know, it's really quite scary ...  :-X. )
Thanks, btw.
http://www.ebay.co.uk/itm/LOCKING-PETROL-FUEL-CAP-4-FIAT-UNO-inc-DIESEL-1983-1995-/360380209219?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item53e8559843
Ciao
Craig
Problem is that these are not an exact fit, being that they are a little difficult to get on and off as the seal is different. These are plastic aftermarket ones and use a different seal so you can't buy one and swap the seal.
So if you do buy one then good chance will be a pain to get on and off..
That is my experience anyways...
The rubber seal you need is 50mm OD, 38mm ID and 3 mm thick but needs to be fuel resistant.
I did find a caffatera seal that was correct size but aint fuel resistant so doesnt last.
No longer as good as I used to be... ::)
