Dellortoman
- Tasmania, Australia
There are two wires that dangle out of the bottom of the RGS engine. One is a red/green wire comes from the neutral switch. The other is a purple wire that according to the wiring diagram is from an oil temperature switch. I wired them into the new wiring harness. Neutral light works as expected, but when the oil temp switch is wired to a light, the light comes on (with a cold engine).
To my way of thinking, an oil temperature light is an over-temperature warning and should only come on if the oil is above a certain temperature.
Since the wiring diagram calls it a switch rather than a sensor, my assumprion was that it drives an oil temp light rather than a gauge. But when I look at an RGS dashboard, there's a temperature gauge but no light.
Can someone shed some light on this? What's the normal operation of the oil temperature switch (or sensor)?
