henrywillms
- Canada
On my RGS the post/stub that the return spring for the rear brake lever wraps around is broken off flush with the adjoining web. So the spring is not grabbing anything. Does anyone know the size (length) of this cast stub, either measured from the inside of the flat casting or from the web. Does it have a groove in it for the spring? Am I best to get a good welder to weld an extension on to remaining stub, or would it be ok to drill and tap a stud into the remaining post. Thanks.
