RGS Printed (Dash) Circuit
Jotaman
Verrierdale, Qld
Howdy,
I am having 'issues' with my printed circuit for my RGS dash (specifically the dash illumination lighting) and was wondering if there is a practical methodology to repair a tear and is it know if there are replacements out there (Wolfgang etc).
Cheers in advance
Peter
Yes, new ones available.
Why try to bodge it as it's a pisser to remove and refit.
Do it once, do it right.
G'day Peter
Well, I'm of a different school of thought. Why replace if you can repair? A good repair isn't a bodge. If you buy another board, how do you know it's any better than the one you have?
I've not actually seen the inside of a RGS instrument panel and the comments below assume the thing has large enough copper tracks to get at with a soldering iron. Sometimes PC boards are bloody microscopic and multi-layered (as in a mobile phone) but a dashboard from the 80's wouldn't be in that category.
The most usual type of failure of printed circuit boards is a poor solder joint, or dry solder joint as it is sometimes known. They can usually be identified by inspection. Look for a solder blob that hasn't "wetted" the component's wire tail properly, or a component that is a bit loose, or poke around with a multi-meter on the lowest Ohm scale checking resistance across solder joints. If you find one that has high resistance, there's your problem. It's a simple job to re-solder and it will be as good as new.
If one of the copper tracks that's broken, or a piece of track missing through some kind of mechanical damage, just bridge it with a bit of copper wire. If the board itself is cracked, you'll need to fix that with epoxy before you tackle the soldering. These types of repair are robust, and not what I would call bodges.
Some PC boards have a coat of insulating varnish over them, in that case you'll need to scrape it off before soldering.
Cam
Been there, done that. I had to repair one of the tracks on the printed circuit on my RGS, the track had cracked where the pcb ribbon bends towards the plugs. As stated, the pcb is coated with varnish, you have to scrap the varnish away to be able to make a good solder joint, I soldered a short length of very expensive teflon coated cable that was supplied by the navy across the break. That was about 25 years ago and still as good as new.
Jotaman said:
Howdy,
Cheers in advance
Peter
Post a pic of your 'tear' and maybe I can walk you thru the repair, I've repaired plenty of circuit cards.
Wayne
Thanks guys,
I had a go at soldering the repair, however was unable to read any power or continuity to this section (upper dash illumination bulbs) of the board, i'll pull it apart again and take some pic's.
I was wondering if you could staple the sections together again - as my soldering efforts were somewhat problematic: tried to solder together then tried to solder a bridge in.
Peter
Peter
There is absolutely no reason why you cant solder some wires into it as long as you scrape away the varnish
Hey wish would have taken some of my modded dash before refitting.
You could always go to Jaycar or similar and buy a printed circuit repair kit but why bother just run some hard wires.
Who is going to see it ?? and it will work just fine... my "trailer queen " did some hard yards recently and all the dash works just fine. If you are worried about reinsulating the solder connection just use some liquid electrical tape works wonders and is the ducks guts for this kind of thing.  Orif you want to go for the originality you can even get circuit board laquar spray
If you look at the top globe tracks you see three... one takes power to the left globe then heads on over the top to the other globe.. the other track goes to earth both. No reason why you can hard wire straight to the globes if you wish... for the earth you could pick up the earth from one of the other screw tabs which are earth and for the illumination pretty sure that one of the other screw terminals is for the lights on light so you could run from there.
I have a couple of spare dashs so if you want will take some pic's tomorrow of the boards and where you can pick up power from.
