I'm having a blonde day:
anyone know what the green / red & green / white wires in the connector block of the left hand switch cluster do?
The wiring diagram shows 9 wires from the switch cluster. My switch cluster has 11 wires at the connector end of it all, 9 of which I've identified.
The new switch cluster I'm intending to replace the ND cluster with has 9 wires, all of which I have identified and I think i've sussed which terminals of the connector block they want to go to. I'm reasonably confident that if I conenct the new cluster up the lights, horn & indicators should work, so what am I missing?
<thinks> the RGS family have a third generator coil that comes on with the lights? I can't spot it in the wiring diagram but I seem to recall you can bypass it & run all 3 coils all the time. Worth doing?
