RGS speedo/tacho cluster repair - who?
Hi Galen, your dash arrived today, will let you know what I find, also got one from Gordon from South Australia.
Finally, had a chance to install  and go for a ride around the county. The speedo now works a treat! Rocksolid. Thank you Jason!
Now to sort out the the wildly swinging tachometer.  As these tachos are digital, could the problem be a faulty filter/electrolytic or something else? Ideas?
-Galen
interference from after market ignition?
didn't that happen at one time with DMC/Witt units? I think Uve supplied a filter or some such.
CEM
The tacho on my RGS started waving about one day, some years back now.
When I looked, I found a small lead weight rattling around the back of the tacho, I could see where it had broken from. Looked like a counter weight to dampen the gauge.
I ended up replacing the innards with an after market one from eBay that had a 3 cylinder setting.
There are some photos here, towards the bottom of the page.
http://www.laverdaforum.com/forum/index.php/topic,41547.15.html
Hope this helps.
Hi Clemtog,-
My RGS  is running the stock Bosch 'light switch' ignition (for the time being ...). Pretty much everything on it I'm trying to keep fairly stock.
Hi Chappo,-
Very ingenious and nicely executed. If I get to the point where I have exhausted all possibility of keeping the stock  configuration, I may take that road up. Looks like the beans and appears to work a treat!
-Galen
