I had my right panel pop-off at speed over the weekend when I finally opens her up, although luckily I caiught it with my leg. I'm also about to take off the airbox and use pod filters instead and I reckon that will increase the wind forces down there.
Yes I have searched and ran out of sanity on page 10 of results mentioning side panels. Fear not I did find some good advice but I figured it would good to see if anyone had developed any new ideas or had had time to confirm one of them.
1. Simplest : Make sure you have serviceable rubber grommets and they are cleaned of all road grime.
Pro: easy to do; Cone: it's still lurking in my mind that it's not really secure.
2. Velcro the panels as well (in addition to cleaning)
Pro: invisible Con: still not fully secure but at least some peace of mind.
3. Deuzz fastners
Pro: secure hard mounted Cons: ugly, non-original mod, need to work out how to mount female receptors
4. Fix eyelets on inside of cover and use bungee or cable ties to secure.
Pros: Secure (as long as your eyelets are attached properly. Cons: fiddly to set up maybe
5. Drill holes in edge of cover...just cons for me on that one!
I like the idea of a hard mounted fastner so going to look at possibilities. Likely to end up with a Velcro setup though after cleaning the grommets. The panels were definitely more secure when they were new.
3. Deuzz fastners
