there seems to be some doubt over oil pump gear width, the only series 11's and RGS pumps that I have seen, have all been 10mm wide, someone did post that RGS pumps are 9mmm wide, which I think is wrong, anyone? although of course an RGS can be fitted with 9mmm wide oil pump gear
The only thing I found when fitting a wider gear to an early engine was the gear overhangs the central boss ( see pics first is the 7mm gear next a 9mm ) the longer centre is available but I think it's a press fit in the cases so I left mine well alone and just fitted the wider gear. Concensous was it should be OK .
