Paul,
The first series drums are easy...
Hoist the front wheel free, loosen the front axle so the drum backing plate is free to move (it doesn't need to slop around, the axle tension just needs to be reduced a bit), spin the front wheel and apply brake hard. Keep applied and tighten axle nut. You now have a base line to work from, the plate/shoes are now centred in the drum, irrespective of condition, wear, etc...
Adjust the stop screw until a shoe touches the drum surface, back off slightly until wheel is entirely free to rotate. Lock the stop screw. You can now adjust the cable to your requirements. Finished. In action, the lever limited by the stop screw is actuated first, further tension on the cable pulls the rear lever tight. You should make sure the levers move in that order, if the rear lever moves first, either the bushes/axles are binding or the return springs have stretched unevenly.
The included angle between levers and cable should not exceed 90? when brake is applied. If you end up with more, you are sacrificing leverage, the linings are worn. When replacing the wheel, after tyre change e.g., it pays off to repeat the centreing process to retain the proper adjustments.
Ideally, new linings can be machined to fit the drum exactly, decreasing break-in time radically. This is where Grants efforts turned into the ball-ache... we misjudged the adjustment range of the 2nd. series drums slightly and he had to painstakingly fit the linings by hand because I had left the linings too thick.
