It's 22mm and 17mm - the drum brake ones are 22/17 the disc are 22/20/17mm - the 20mm being for the area between the fork legs on disc brake models. - Regards - Phil
I'm in the process of fitting a Beemer /5 twin leader into a G80CS! Fits quite well, looks period and isn't too much hassle... if you can find a decent one, that is. Just hope the spindly forks will stand up to it. :
I fitted a /6 to my last G80CS. 17mm spindle was perfect.
Sounds like the Laverda spindle is too wide for Matchless forks. The only other forks I have at the moment are Ceriani 38mm which are on my GT to make a rolling chassis.
