phil37 said:I Loctite the "Jesus" nut and fit one of my larger O.D tab washers too. I recommend "Fu-----ng Tight" too. I warm up the clutch drum when I remove the rivets to avoid any risk of splitting the cush rubber pillars. I prefer 7mm bolts and use a spring washer under heads - but, as Piet has pointed out, this will require some relieving of the g/box mainshaft support struts. I've got the 7mm bolts if you need them. - regards - Phil
Glawster said:Thanks for all your help on this point.
There is just perceptible "wobble" on the clutch drum, but it's difficult to isolate it from the end float on the shaft.
The visible main bearing is a roller so I'm assuming it's been replaced.
At this stage - seeing no potential catastrophes - I'm minded to put the cover back on and cover a few miles to see how it develops. Replacing the clutch cush drives sounds a fairly major job that I may have to come to, but maybe not just yet.
Once again - great support guys. I'm learning a lot!
Derek
You'll need to rock the rear wheel backward and forward taking up the lash while trying to select either up or down. No way you'll select a gear if you have the wheel static. Is the small cover off? If not are you sure the spring isn't getting between the eccentric bolt and the selector limit plate?earthcore said:any hints much appreciated
ive got a fair way from the box of bits but this has got me stumped
